Need help
   / Need help #1
ben21921
Elkton, Maryland
none/ yet
Have a fairly new LS xr3037 H I was getting ready to mow so I took the bucket off and after I took the bucket off the front end loader will not raise or lower it will tilt and curl fine but something feels like it's stuck when I try to raise or lower it any suggestions?
   / Need help #2
In front of the joy stick, there is a little silver tab that you can push in to lock out the stick. check to see if you hit it by accident. Pull hard on it to get it to unlock. I did it to mine when it was new.
George
   / Need help #3
Sorry, I was wrong. I went out and checked my XR3135HC, and it is not the little tab, your joystick has gotten pushed forward into float position, pull back hard on the stick and it will snap back to where it should be. When new they snap hard or stick
George
   / Need help
That was it thanks so much. I read that in the Manuel but your right I really had to pull hard. Thank you
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
2006 Freightliner Business Class M2 Beverage Truck (A47384)
2006 Freightliner...
2014 CATERPILLAR 349FL EXCAVATOR (A51242)
2014 CATERPILLAR...
Bad Boy Maverick 5200 Zero Turn Mower (A50514)
Bad Boy Maverick...
UNUSED JCT SKID STEER QUICK ATTACH TRENCHER (A51244)
UNUSED JCT SKID...
SET OF CAT SKID STEER QUICK ATTACH PALLET FORKS (A51242)
SET OF CAT SKID...
