Need help!
   / Need help! #1
cowboy1951
Sierra Blanca, Texas
Case D530TC Backhoe Frontend loader
While operating my D530TC backhoe it started to lose power and then just shut down. Now it will not start. Plenty of fuel and oil. Any suggestions? Thank you in advance.
charles
   / Need help! #2
Does inj pump have an electric fuel control solenoid? If so is it operating correctly? What type fuel system inj pump or other type?
   / Need help! #3
If it lost power slowly. Then that could indicate a clogged fuel filter or collapsing line. Change fuel filter first.
   / Need help!
It has new fuel filters but I will pull them out and check their condition. Thank you.
   / Need help!
I am not sure if it does or not. I will go check. It has the A35774 Fuel Injection Pump according to the parts manual.
   / Need help!
The parts manual doesn't show an electric fuel control solenoid.
   / Need help!
Nothing electrical anywhere near the fuel control. Fuel filters look good with plenty of fuel and no trash. Although the fuel line needs replacing, it isn't visibly collapsed anywhere.
   / Need help!
I hope I am doing this right. I am attaching a copy of the fuel system diagram.
  • Fuel System.pdf
   / Need help! #9
No diagram. Ok new filters. Steel lines don't collapse they plug. But any rubber lines can collapse. Check the condition of all lines. Check and make sure tank isn't plugged. Start at tank and see where full stops flowing. That's your problem.
Any lift pumps that can go bad?
   / Need help!
Sorry about the diagram. Have good fuel flow all the way from the diesel tank thru the filters and into the fuel control. No lift pump or any kind of pumps that can go bad.
AFF 8888 CANTILEVER WASTE OIL DRAIN (A51248)
AFF 8888...
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
Hydraulic 80mm Quick Coupler (A52384)
Hydraulic 80mm...
DEWALT 3400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 3400 PSI...
2016 Atlas V4 Towable Light Tower (A51691)
2016 Atlas V4...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
