Need help
/ Need help #1
draggingems
London, KY
Branson 3510
When I raise the 3 point attachment (regardless of what it is) all the way up, it bogs down the motor. When I let down just a little bit to where the engine will run normal, the attachment jerks like crazy. I'm not a mechanic at all but was wondering if this was something simple I could fix.
/ Need help #2
When you raise all the way the lift cylinder is at the end of it's travel. The hydraulic system is still supplying pressure. Since the cylinder can't move any more the pressure will increase until the system relief valve opens.The load on the engine from the pump going to maximum pressure is why your engine bogs.
/ Need help
I understand that but this just started happening so is there a problem with the relief valve? It doesn't "release" pressure and is a constant bog on engine if I leave up.
/ Need help #4
Linkage adjustment. Three point is supposed to raise to a position controlled by your position lever. Top position is supposed to be set prior to the cylinder reaching the end of the stroke so the oil will never go over relief (unless you lift something greater than the lift capacity). Check the feedback linkage that may have come out of adjustment.
Land honor Mini Skid Steer (A60352)
Land honor Mini...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
Hitachi EX 270 LC, Cab, 32" Track Pads, Grapple (A62679)
Hitachi EX 270 LC...
2019 RAM 5500 4X4 S/A ROLLBACK TRUCK (A59914)
2019 RAM 5500 4X4...
1993 International 4900 Utility Flatbed Truck (A64194)
1993 International...
2016 BOBCAT E35I MINI EXCAVATOR (A62613)
2016 BOBCAT E35I...
