Need help working on old Walker Floor Jack (1960's)
   / Need help working on old Walker Floor Jack (1960's) #1
pharmvet
Platinum Member
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
I was given a 4 ton Walker Floor Jack by a friend. It needs a little TLC and a few replacement parts. I found a company that has most of the parts. I am currently trying to take the handle off. It has a rod running through it with a cap on tow that is used to turn the release valve. The cap has a little push pin with a detent. I was told that this pin needed to be reomved in order to take off the cap in order to remove the handle. I proceeded to break the pin trying to remove it. Once it was remove the @@##@!$$%% cap still wont come off. I cannot for the life of me find anything holding it. I can only accume it is a press or expansion fit. How in the #$#$%^^@@ does it come off????? HELP please.
   / Need help working on old Walker Floor Jack (1960's) #2
Don't know about your Walker, but I have an old Nike jack.{ same vintage as yours} The valve release shaft will come apart at the bottom of the handle and let you remove the handle that way. Good luck
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
Galvanized Livestock Gates - (5x Gates) (A55218)
Galvanized...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
CATERPILLAR 302.7CR EXCAVATOR (A52705)
CATERPILLAR...
2015 TAKEUCHI TL10 SKID STEER (A52705)
2015 TAKEUCHI TL10...
