Need help working on old Walker Floor Jack (1960's)
   / Need help working on old Walker Floor Jack (1960's) #1
pharmvet
Platinum Member
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
I was given a 4 ton Walker Floor Jack by a friend. It needs a little TLC and a few replacement parts. I found a company that has most of the parts. I am currently trying to take the handle off. It has a rod running through it with a cap on tow that is used to turn the release valve. The cap has a little push pin with a detent. I was told that this pin needed to be reomved in order to take off the cap in order to remove the handle. I proceeded to break the pin trying to remove it. Once it was remove the @@##@!$$%% cap still wont come off. I cannot for the life of me find anything holding it. I can only accume it is a press or expansion fit. How in the #$#$%^^@@ does it come off????? HELP please.
   / Need help working on old Walker Floor Jack (1960's) #2
Don't know about your Walker, but I have an old Nike jack.{ same vintage as yours} The valve release shaft will come apart at the bottom of the handle and let you remove the handle that way. Good luck
2012 CATERPILLAR D6T XW HI-TRACK CRAWLER DOZER (A51406)
2012 CATERPILLAR...
1002 (A47477)
1002 (A47477)
2012 MACK CHU (PINNACLE/ RAWHIDE EDITION) DAY CAB (A54607)
2012 MACK CHU...
40" WIDE STAIRCASE W/ METAL RAILING (A54757)
40" WIDE STAIRCASE...
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
Houle 48-6D-5250 Manure Tanker (A50775)
Houle 48-6D-5250...
