Need help with15LA loader support stand reinstallation
   / Need help with15LA loader support stand reinstallation #1
adlertom
Southern Wisconsin
New Holland TC33DA hydro w/supersteer
I took the loader support stand off my New Holland 15LA loader (did not remove the loader from the tractor, just the support stand from the loader). A few weeks later, I went to put the support stand back on, and got confused. I'm not sure that I have it on the way it was originally. I should've taken "before" photos.
Here are the "after" photos. Is this correct?
I've read here that this support stand isn't the best design, and I never remove my loader anyways. I just want to get the stand back on the loader as it was originally, just in case I do ever need to remove it.
   / Need help with15LA loader support stand reinstallation #2
Looks good to me. I checked my TC40 and as long as mine is set up right, it is set up in the same configuration as yours.
I once took the loader off, I believe I followed jinman's (RIP) thread on how to do so. Boy, does that tractor get small and goofy looking with no FEL attached!
   / Need help with15LA loader support stand reinstallation #3
Looks to me that you have it on correct... Matches how ours is on the 16LA that is on the TC40D & we use ours a couple times a year with no issue...
Thank you
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
1995 Ford F-250  7.3L Powerstroke Diesel (2WD, Long Bed) (A55315)
1995 Ford F-250...
Kubota M5-111 (A53317)
Red Cedar Wood Swing Bench (A55853)
Red Cedar Wood...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Horse Weathervane (A55853)
Horse Weathervane...
