Need help with wiring diagram for New Holland TC33D 2 style of harnesses.
   / Need help with wiring diagram for New Holland TC33D 2 style of harnesses. #1
sdman32
San Diego,CA
john deere
I have a TC33 that the rats ate the harness up in picture 1. The replacement harness I have is in picture 2. My problem is that my manual only shows the schematic for harness 1 and not 2. Can anyone identify which model picture 2 is off and where I can find the schematic? I would be grateful if anyone could share the schematic for harness 2. Thank you
   / Need help with wiring diagram for New Holland TC33D 2 style of harnesses. #2
I'm wondering if you have harness for a non-deluxe model, or if there is a difference
between the harness for a TC33 and a TC33D.
Refer to the attached PDF, the deluxe has a 20 amp fuse solely for the front lights, on the non-deluxe the front lights and rear flashers use the same 20 amp fuse?
  • Fuse Block - From Service Manual.pdf
I need a complete schematic of the loom #2. Loom number 2 might have a turn signal switch and has multiple other plugs that my tc33 does not. I want to make Loom 2 work. Loom 2 has all the same as Loom 1 but has additional plugs, and wiring is routed differently to different relays such as start, glow ect.
   / Need help with wiring diagram for New Holland TC33D 2 style of harnesses. #4
I have the manual for a TC29D and it covers TC33D. I'm not up on the terminology, so if you could explain better what you need, I will see if I can help.
Also, is it HST or gear? Yes, it makes a difference...
   / Need help with wiring diagram for New Holland TC33D 2 style of harnesses. #5
What does your fuse panel look like, is the fuse in the 3rd slot from the top a 20 amp or 7.5 amp?
   / Need help with wiring diagram for New Holland TC33D 2 style of harnesses. #7
Trying...
Here are the fuse block pictures. I have the diagram for 1, as shown. I need diagram #2, and I don't know which model it came off for #2. its a HST
   / Need help with wiring diagram for New Holland TC33D 2 style of harnesses. #9
It's difficult for me to tell from the pictures of the fuses, but my guess is the 3rd fuse from the top in both pictures is a 20 amp which would lend me to believe they are both deluxe version. The schematic which you posted is labeled as a deluxe.
Attached is a PDF of both the deluxe and economy TC series tractor's electrical schematics. I hope you are able to figure it out.
  • TC Deluxe - Economy Elec Schematic's.pdf
Thank you for the help.
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
2017 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A55851)
2017 Takeuchi...
(2) PALLETS OF TRAILER JACKS & MISC TRAILER PARTS (A54757)
(2) PALLETS OF...
300 GALLON PULL BEHIND SPRAYER TANK (A57192)
300 GALLON PULL...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A56435)
2006 Heil Tanker...
2017 10ft. Bush Hog Rotary Brush Cutter Tractor Attachment (A55851)
2017 10ft. Bush...
