Need help with winch installation
   / Need help with winch installation #1
General Lee
Veteran Member
Mid-Atlantic
Kubota L4400, B2401
I installed a winch on my RTV500, the same setup at Beretta96man. I got everything bolted up and wires run, however, I'm not sure which *key on hot wire* to splice into. Instructions call for you to join the remote control rocker switch's red wire and the rocker switch red wire into the red wire on the key switch. I'm not comfortable cutting the factory ignition wire to do this. Plus I'm really not sure which wire it is. I do see a red wire coming from the ignition but its in a harness tied into numerous other wires. Not the easiest thing to do IMO.
How has everyone else tied in the rocker switch wires on your winches?
I may have it figured out. Even though I kept referring to Berretta96man's post on his installation, I guess I read through number 8 a little fast. If I understood his procedure correctly, I did the same. Now I have to pick up a male end bullet style connector and plug up the switch wire, Then wind the the rope on and I'm done.
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
2002 New Holland TN75S 4X4 Loader Tractor (A51243)
2002 New Holland...
2025 CFG Industrial EXAB56 78in Hydraulic Broom Excavator Attachment (A49462)
2025 CFG...
2006 IC Corporation PB105 School Bus (A50323)
2006 IC...
Mid-Back Office Chair (A49462)
Mid-Back Office...
2024 LandHonor VSL-22-96W Cat II Hydraulic Hay Bale Unroller Attachment (A49462)
2024 LandHonor...
