Ballast Need help with wheel weights for Kubota L3830
   / Need help with wheel weights for Kubota L3830 #31
Tire ballast does not take the place of 3pt hitch ballast for loader work. Doing fel work with no 3 pt ballast will kill the front axle components. May take a few years to see the damage.
Your definitely right but i haven't figured out what i can put on the back of my tractor that weighs over 1500 lbs and still maintains some level of maneuverability. 1800 lbs of rim guard and 1000 - 1500 lbs of rear ballast is barely enough for heavy loads. You need both types of ballast the more on the 3 pt the better.
Dave
   / Need help with wheel weights for Kubota L3830 #32
Dave
Any weight is better than none.
You will eventually have front end problems using fel with no 3 pt ballast.
   / Need help with wheel weights for Kubota L3830 #33
Yep i agreed with you and with that said i try to always have at least 1000 - 1500 lbs on the 3pt when lifting more than a 1000 lbs. but i could not do it with just rear ballast as i dont have that much weight to hang on it. A gannon 84" box blade only weighs 1300 lbs. My ballast box loaded weighs about 1500# a 2000 lb brush cutter would be great if you dont mind the extra 8 or 9 feet of length it adds to the tractor. I rarely take my carryall ballast box of which weighs close to 500 lbs. When i lift 3000 lb pallets id like to find a way to hang 2000 lbs plus 1800 lbs of rim guard but have yet to find a good solution that does not make the tractor to long
Dave
   / Need help with wheel weights for Kubota L3830 #34
Dave, sounds like you know what you're doing. You'll figure something out.
Toro 880 Procore (A55758)
Toro 880 Procore...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
1985 Ford Ltl9000 Tender Truck (A56435)
1985 Ford Ltl9000...
Kubota K7874 18in Digging Tooth Bucket Excavator Attachment (A55973)
Kubota K7874 18in...
Mini Skid-Steer Concrete Mixing Bucket (New/Unused) (A59225)
Mini Skid-Steer...
2004 FORD F-650 SUPER DUTY CAB AND CHASSIS (A58214)
2004 FORD F-650...
