dieselfuelonly
Yanmar + Bobcat + Cummins + Trailer = COOL TEAM... however, I have no idea if the weight would be distributed correctly.
According to TractorData.com:
The Yanmar weighs in at 1168lbs.
According to DiggerData.com:
The Bobcat weights 4730lbs.
That comes to 5898lbs.
Ok, lets be on the safe side and round that to up 6000lbs. And I'm not sure if the weight of the Bobcat bucket is included in the weight that DiggerData.com gives. And don't forget the box blade, its not SUPER heavy since its only a 4', but it is heavy enough for sure.
Now, FORUM SAFTEY PATROLLERS:
1. I AM NOT GOING ANYWHERE
2. YES, I HAVE NO CHAINS/BINDERS YET, HENCE #1
3. THE CLASS V HITCH I BOUGHT HAS NOT ARRIVED YET, ALSO HENCE #1
Anyway, I put some jack stands under the rear of the trailer for safteys sake in case it tried to lift the rear of the truck off the ground. I don't know if it would, but it was my first time loading my stuff on the trailer.
The problem is, the rear of the trailer is now resting on the jack stands.
The rear of the truck is sitting a little lower, too.
Does the weight look like it would be distributed safely, or do I need to re-think how I load the machines, if I even load both of them at all.
Thanks!
Also, if anyone sees any glaring mistakes in the pictures, saftey or otherwise that I made, PLEASE point them out, besides the obvious ones that I stated above.
Thanks!
