Need help with steering column seal replacement!!!!
   / Need help with steering column seal replacement!!!! #11
After you get the wheel off... the tube will unscrew from the base of the column... after that is off there are 3 bolts.. remove the three bolts and boom you got it off... after that remove snap ring and remove oil seal.... steering wheel is the hardest part of the job.
Many thanks!
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A56436)
LMC 2-Row Planter...
1995 Ford F-250  7.3L Powerstroke Diesel (2WD, Long Bed) (A56435)
1995 Ford F-250...
Bucket (A55973)
Bucket (A55973)
2019 Ford Explorer (A55788)
2019 Ford Explorer...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
