Need help with pumping septic
   / Need help with pumping septic #1
jbarker855
Collins, NY
John Deere 855
Hello all-
I have 1000 gallon septic tank but my problem is that we have a fairly small bridge on our property that no septic truck companies are willing to cross. They used to years ago, but as time goes by most of the companies have gotten rid of their smaller trucks. Additionally as time goes by, there seems to be more worry about getting sued for this or that so they are unwilling to attempt crossing our bridge anymore. I have called just about every company around. I have come to the conclusion that it would be easier just to pump it myself. I do have a company who is willing to pull his truck up to the bridge and then I will pump it into his truck. The bridge is about 300 feet from the septic tank. Luckily, it is a downhill run. Probably goes down 5 or 10 vertical feet.
My question Is what type of pump should I buy and what size hose. I could get an electric sewage ejector pump or I could buy a gas powered trash or semi trash pump.The electric pumps are in the neighborhood of 1/2hp, 25 feet max head, 80 gallons per minute, 2 inch discharge, handles soft solids up to 2 inches.
For a gas pump, Harbor freight offers three different options, Ranging from 158 to 380 gallons per minute. They do not specify horsepower ratings on the engine but they look like they range in size from roughly 5 to 8 hp. The smaller gas powered pump has a 2 inch inlet and outlet. The larger pumps have 3 inch inlets and outlets. They are designed to pass hard solids from five eights to three-quarter inch diameter.
I am willing to buy any equipment necessary but I do not want to buy unnecessarily oversized equipment. I understand I will need to use a muck rake to break up the scum layer and to lift up solids from the bottom.
Any advice on pump sizing or other thoughts would be greatly appreciated.
As a last thought, please just accept it as a given that pumping the tank myself is our last option. Reinforcing the bridge really is not an option (it is 90 feet long). I do not want to petition a town for sewer hook up (there is none). And I understand that there are germs in poop.
Thanks!
-Jay
   / Need help with pumping septic #2
Can't you find an operator with smaller equipment? Maybe do it in two pumping sessions. Like a small pickup that handles porta-potties? Messing with poop would be the last thing I would feel like doing. How would you clean the equipment? Do you have a thousand gallon tank and truck to transport the material?
Curious on your thoughts about getting fire fighting equipment to your buildings.
   / Need help with pumping septic #3
if no fire trucks will go across = no homeowner insurance
   / Need help with pumping septic #4
I had mine pumped for the first time after about 30 years. We have always used "Riddex" type enzymes and hardly had any hard scum layer. However, we did suck out a few small kids toys and a lot of handi-wipes that shouldn't have ever been flushed.
The pump and hoses will get very expensive. Why not just have the Vacuum Truck suck out the tank from the bridge. They could use all of their hose available and you could just make up the difference with hose. Of course, that could be to far to suck and must be pumped up the hill. No place to rent a pump?
   / Need help with pumping septic #5
I can't imagine that the bridge is the only way to access the septic, that's one side, what about the other three sides without a bridge??..
   / Need help with pumping septic #6
I would ask the company that does the pumping what they would recommend. I assume they will still come, you just have to pump to them?
   / Need help with pumping septic #7
All the septic trucks that I have seen were vacuum units.
Before I would consider a pump I would price enough hose to add to whomever you have come out to "pump" it.
Or/and just a small grinder type pump to circulate and churn up the tank so it all sucks out.
As far as being afraid of it, it's just organic material.
   / Need help with pumping septic #8
A combo of you pumping and them sucking may actually work well. Or, find out where all the small vacuum trucks have gone and go buy or rent one.
   / Need help with pumping septic #9
I would buy a new bridge, instead of a septic pump. The bridge is much more multi-purpose.
   / Need help with pumping septic #10
300 ft with a downhill run looks feasible for a vacuum truck. May be too much pipe resistance.
2015 Ram 1500 Crew Cab Pickup Truck (A49461)
2015 Ram 1500 Crew...
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
2015 Ford Taurus AWD Sedan (A48082)
2015 Ford Taurus...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2018 Chevrolet Camaro 1LT Coupe (A48082)
2018 Chevrolet...
8ft. Enclosed Cargo S/A Trailer (A48082)
8ft. Enclosed...
