Need help with PTO pump shaft setup
   / Need help with PTO pump shaft setup #1
backintheday
Wyoming
Branson 3510H
Hi all,
I built a PTO power pack to run a hydraulic snow blower, I've decided to mount the pump to the power pack. My question is what is the best way to drive the pump, the distance from the tractor pto to the pump is 22". I haven't seen any pto shafts that are less then 24" I have seen where another member used this Double U Joint 1 1 4" Round to 1 3 8 6 Spline 540 PTO Universal | eBay, double U joint but I'm not sure this is the best for my application. The angle from the pto output to the pump is fairly flat. The PTO pump is a prince style pump with a 6 spline 1 3/8 input.
This is the last thing I need to complete my set up. Thanks for the help guys.
   / Need help with PTO pump shaft setup #2
PTO shafts are commonly cut down to size, just remember to take HALF from each end.
[they pull apart in case you haven't taken one apart before]
You can search for the proper way to measure/cut the PTO shaft, but it is a simple process.
2002 Miller Trailblazer 301G Towable Welder Generator (A59228)
2002 Miller...
2013 Infiniti G37 Coupe (A59231)
2013 Infiniti G37...
2022 CATERPILLAR 249D3 SKID STEER (A60429)
2022 CATERPILLAR...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
SKID STEER ATTACHMENT TILLER (A58214)
SKID STEER...
2387 (A60432)
2387 (A60432)
