Need Help with Old Cub Cadet...
   / Need Help with Old Cub Cadet... #11
Hi Joe,
Another great product is PB Blaster, it'a a penetrating oil I've had great luck with. Is the mowing frame mounted (mule drive)on the tractor?
I think once you get e diagram it will all make sense.
I've used large breaker bars with pipe extensions and a block of wood to keep the blade from turning, once they're off, grease them with a lithium or white grease before replacing, they'll come right off next time.
Good luck, I owned a 149, it was a fine piece of machinery
Curt
   / Need Help with Old Cub Cadet... #12
Yeah, I did too--but all I found was tractor or engine manual--no deck manual. Thanks though.
Jack
   / Need Help with Old Cub Cadet... #13
Jack,
I'm guessing that deck is the 44C, what specifically are you looking for. I probably have a diagram or something close.
Curt
   / Need Help with Old Cub Cadet... #14
Also, for NCIT, the 44C might be pretty similar to the deck on your 169. My 149 was very similar to the 44C on an 1860 I owned. I can scan the deck and mule drive and email them to both of you if you're interested.
Curt
   / Need Help with Old Cub Cadet... #15
Hi Curt--it would be right neighborlyof you to scan the info on the 44 in deck for Cadet 1860. My e-mail is jmaansfie@post.harvard.edu
The deck info plate says 441U111--nothing else.
Jack
   / Need Help with Old Cub Cadet... #17
Hey Jack,
They're on their way. Let me know if you need help.
Curt
2015 Ford F-350 4x4 Cab and Chassis Truck (A53422)
2015 Ford F-350...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2018 Ford F-150...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A54811)
1996 JLG Commander...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
