Need help with my Ford 9N tractor, any ideas would help!
   / Need help with my Ford 9N tractor, any ideas would help! #1
trytofixit
mt.ranch,ca.
ford9n, J.D.A,farm.H
I have a Ford 9N tractor with no rear PTO or rear lift on the three point hitch. Any ideas? thanks in advance
   / Need help with my Ford 9N tractor, any ideas would help! #2
does it have a delete cover on the back end where the pto would have been?
does it have a standard top cover with upper lift arms, or a delete plate.. or a top cover and no lift arms and no rockshaft.. or does it have a rockshaft.
lastly, is the belly pump present.. or is it simply a delete cover on the bottom of the center section.
if it is missing the pto shaft.. it likely has no hyd pump.. if no pump.. it may have been an industrial or other machine.. and to add the top cover, pump and pto shaft may be cheaper to buy the back end of a junked 9n that has the stuff.. then swap parts.. or entire rear...
This tractor has all the options and they all worked awhile ago. By all, I mean the PTO & the three point lift arms. I am going to go work on it tomorrow,this Ford is my Nephews. It's been awhile since I worked on one , he said I fixed the problem before but I don't remember. Any help would be appreciated. Thanks in advance!
   / Need help with my Ford 9N tractor, any ideas would help! #4
So when you say "you have no rear pto or 3-point lift" you mean you DO have them but they do not work???
If thats the case, you may have a busted PTO shaft. Take out the 4 bolts around it and pull it out. (Might want to drain the fluid first:D)
The hydraulics are driven by the PTO. That would explaing why neither work. If it isnt the PTO shaft, it is something farther upstream and going to take more digging. It may simply be something broke and not engaging???
If it is the PTO shaft, for about the same $$$, you can get the 1-3/8 spline shaft and not have to use adapters for modern 540PTO implements.:thumbsup:
   / Need help with my Ford 9N tractor, any ideas would help! #5
oh.. saying it dind't have a pto threw me off into right field.
first, make sure pto lever is engaged properly.. if it feeld like it engages.. but no pto or hyds, make sur ehte thractor will move.. IE.. the tranny is getting power.
pull the inspection cover on the right side.. look thru as someone operates the pto engage lever .. see if it moves the sliding dog clutch.. sometimes the arm moves and nothing else does.
you can remove that pto lever cover as well for a looksee
i've posted a diagram of the pto shifter mechanism used on the N series.
if you feel like that is working, then park nose down a bit and see about pulling the pto shaft.. might have the end chewed off or something.. like a brake..e tc..
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2023 QUALITY CARGO 16 T/A ENCLOSED TRAILER (A50854)
2023 QUALITY CARGO...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A48081)
2011 Ford F-550...
20 Gallon Air Compressor (A50860)
20 Gallon Air...
2015 Ford F-350 4x4 Knapheide Service Truck (A48081)
2015 Ford F-350...
