need help with hydraulics
   / need help with hydraulics #1
joe woodum
satoh 655g
just got a satoh tractor s650g with front loader bucket 3ph and a pto. having an issue with hydraulics it works but very jumpy and sluguish. i've been told to check out the filters and fluid levels.fluids seem to be ok a little clowdy coffee coloured will prob put new oil but can anybody tel me were to find filters or do i have a screen and were would that be located.and were the vent are and how do i clean? any help would be apprecitated thanks! joe
   / need help with hydraulics #3
Welcome to TBN:D
The coffee colored fluid is most likely your problem, it means that the fluid has water in it. Can't help with filter locations and such-but you need to change that fluid and find out where it's getting in the system.
   / need help with hydraulics #4
check on the case under the rear wheel area . look for 2 bolts that is holding down a oval shaped plate .this may be on the brake pedal side.put a large pail under there and open the bolts. remove the plate and screen.wash the screen with solvent and soft brush.put back together with new fluid.
   / need help with hydraulics #5
Black coffee color> burnt fluid
Chocolate milkshake color> moisture in fluid
Either way the fluid should be changed and the screen serviced
I ordered some parts and a owners manual from Valley Power and was
impressed with the person I talked to (Bill) he was a bid help and has
alot of knowledge of Satoh tractors. Their email address is below.
satohparts.com
   / need help with hydraulics #6
I have a 1971 satoh 650g and if your tractor is anything like mine , you will need to drain the hydraulic tank under the seat ( holds about a gallon) . The screen is at the bottom of the tank . You will need to remove the large bolt holding the steel hydraulic line to get the filter out . The filter is a piece of pipe surrounded by a fine brass screen .
   / need help with hydraulics #7
having an issue with hydraulics it works but very jumpy and sluguish. thanks! joe
Milky oil, jumpy and sluggish could be air entrainment from bad suction hose/tube/fitting/pump shaft seal....No????....jumpy and sluggish kinda gives it away as air suction leak and/or cavitation.......
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATE (A54757)
UNUSED LANDHONOR...
CAT Skid Steer (A50322)
CAT Skid Steer...
2018 Ford F-250 Reading Enclosed Service Truck (A53422)
2018 Ford F-250...
UNUSED WOLVERINE JMR-22-8.5G 1R RIPPER (A54757)
UNUSED WOLVERINE...
2014 BMW 328i Sedan (A53424)
2014 BMW 328i...
