Need help with Hydraulics on L3750
   / Need help with Hydraulics on L3750 #1
Davaron
I had to replace the housing where the shifter lever goes into the top of the transmission under the seat. Quick on and off. SInce then I have had problems with the lift. Worked fine before I replaced the housing. Seems to work OK when cold but as it gets warmed up it will not lift. It will not sag down, it will hold but not lift. If you leave it awhile and let it cool down it will lift again for a bit then stop working as it warms up. I have replaced the filter and drained and replaced the fliud but no help. Any ideas?
Aluminum Scaffolding (A57454)
Aluminum...
20 LOWBOY BUMPER PULL TRAILER (A58214)
20 LOWBOY BUMPER...
1980 Gleaner F2 with heads (A56436)
1980 Gleaner F2...
Kubota BX25D (A53317)
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
2017 John Deere 1025R Tractor - 626 Engine Hours (A56436)
2017 John Deere...
