Spreader Need help with drop spreader
   / Need help with drop spreader #11
Hey Barney. Have you ever tried spreading bulk lime with yours? Bulk tends to be less clean and more clumps than what you get in bags, but also a lot less money. I was thinking of building one, but my food plots are small enough if I could pick up something like one of these it would be worth it.
   / Need help with drop spreader #12
The only lime I've spread has been out of bags, but the gates on my spreader will open pretty wide and I think the agitators are pretty effective. I've used mine 1 season and have spread about 8 ton of lime with it on my small plots. I bought it last year about this time. :)
Hey drivadesl,
I bought the spreader from a fellow who had used it in Tenn. Said thats all his father used to put out lime, I asked about bulk and he said yes. Haven't had a chance to use it yet but the Local fert. store said bulk was $35 a ton and they are only 14 miles from my hunting lease. They will deliver for about $50 for up to 5T. I think I'll just pick up a couple tons in a dump trlr. and make a few trips. will be easier to load off the trailer than off the ground. Also just purchased a manual off ebay for $10 with shipping it should give adjustment rates as the chart under the lid is about gone. Have no idea how much it will hold.
OK just came back from a day of spreading lime and fertilizer. Spreader worked well. Looked inside the lid and found a partial application chart.
Partial meaning a good portion was missing. I did see a chart stating David Bradley basic spreader it referred to adjusting the bolt/bolt stop shown in the pics under the middle of the spreader. I straightened the angle iron piece in the pics. Part of the wording states turning the bolt 1 1/2 turns opens the slots 1/16th " I think I saw where 9/16 allowed for 1046? lbs per acre.
Any one have any Ideas or can help with the chart and the bolt adjustment.
Loaded by hand took us (3) about 3 minutes with shovels-lime also
14 50# bags 10-10-10 and it was full.
2012 International 4300 Reefer Truck (A57024)
2012 International...
2018 K-TEC 1228 PULL TYPE DIRT PAN (A52707)
2018 K-TEC 1228...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
2003 Big Tex 10PI...
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A51692)
2013 Mitsubishi...
John Dozer JD650 (A51691)
John Dozer JD650...
