Planters Need help with Dempster planter
   / Need help with Dempster planter #1
Nickahawk
South Cen Kansas
Kubota '2007 L4400, JD '1973 1020 3 cly gas/w FEL
I'm trying to get an old Dempster planter model 302, to plant sweet corn. I've enlarged the plate holes so corn will pass thru it, but not evenly, and I'm not sure what to do next.
Any help will be great!
Nica
   / Need help with Dempster planter #2
I have a 302 also but i find same problem , so bought a reverse tine tiller
to go ahead of planter that tills real fine this helps it cover seeds better
for the planter . Also installed plates with square holes ( with closer holes )
more fits a square kernal of corn this also helped a lot , sorry thats all i
have :)
   / Need help with Dempster planter #3
Here is a blurb below from Lincoln Ag. This seems to indicate plates are available for the Demster. I don't know if it applies to your particular model.
If your plates actually will interchange with JD almost anything is available. JD plates are plentiful on E-Bay as well as Lincoln Ag.
For DEERE, also 1968 & later models of WHITE (M.M., OLIVER) COCKSHUTT, DEMPSTER, COLE, MARLISS, 1976 & later models of FORD 352 (pull type) & K.M.C. (KELLY MFG. CO.) To use in ALLIS-CHALMER, Adaptor below is needed.
2018 TowMaster T-12D T/A Flatbed Trailer (A55852)
2018 TowMaster...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
1989 Hyster H40-XL-MIL 4,000lb Diesel Forklift (A55851)
1989 Hyster...
Hr:8,875 vin:316000649 (A53421)
Hr:8,875...
3 WHEEL ELECTRIC GOLF CART (A55745)
3 WHEEL ELECTRIC...
