Need help with axle seal behind hub on a 3320
   / Need help with axle seal behind hub on a 3320 #1
XviperX2
Lehigh County, PA
JD 3320 ehydro
I lost all the fluid in my front axle after a 12 hour day of digging and moving dirt with my FEL, I am sure it is just the seal after reading some other posts on here but I am stuck?? I have removed the clip and tried to use an 8" gear puller on the gear but i cant get the bearing to move at all. What am i doing wrong??? Thanks for any advise you can give!
   / Need help with axle seal behind hub on a 3320 #2
My hub is the same. I used a press and pushed on the shaft once the
circlip was removed. As I recall, you can't get a puller behind the bearing
by itself. Spicer uses interference fit bearings, unfortunately.
   / Need help with axle seal behind hub on a 3320 #3
As DF said use a press. I hope you too the c clip off before trying the puller.
Matt;)
Thanks i was able to get it with the gear puller. once i had it as tight as i could i hit the center screw on the puller, it broke free then came off fairly easy.
   / Need help with axle seal behind hub on a 3320 #5
Do you by chance have a pic of the puller setup that you used?
Glad it worked for you, and some of may be faced with the same problem sooner or later. :)
Thanks
   / Need help with axle seal behind hub on a 3320 #6
The correct tool to put it back on is a press, too, but I suppose a
hammer will work.
2011 Cadillac SRX Luxury SUV (A50324)
2011 Cadillac SRX...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
2013 JLG G9-43A Telehandler (RUNS) (SMOKES) (A50774)
2013 JLG G9-43A...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
