need help with auxillary light switch
   / need help with auxillary light switch #1
Docwho
Howard, PA
New Holland/TC40
Hello
Need some help with wiring in auxiliary switches on a 2003 New Holland TC40. The switches have 5 blades.
Un-shore of where to bring in the power and what all of the blades are for. Please help!
need some good advise.
   / need help with auxillary light switch #2
Most multi-blade plugs have the post marked on the side of the plug or inside next to the plug. Without seeing it, it will be difficult to advise on what is what.
   / need help with auxillary light switch #3
Got Pics?
Way too may wiring options without a reference point.
   / need help with auxillary light switch #4
Sounds like they may be lighted switches or double throw but we still need to know what type and make. Diagrams are normally supplied by the maker. And as noted above, will be on the switch or available from the maker's website. Do a interweb search on the brand and model. There should be something. There are too many variables between brands and models to suggest universal connections.
Or you can do it the hard way and map the pin out yourself with a meter.
Thanks all
I figured it out. Front pin ground middle to pins power in, bottom 2 pins power out.
Turfco Mete-R-Matic XL Towable Golf Course Drop-Style Topdresser (A55973)
Turfco...
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
2014 Chevrolet Silverado 1500 (A55973)
2014 Chevrolet...
2012 GALLEGOS 130 BBL STEEL VACUUM TRAILER (A58214)
2012 GALLEGOS 130...
