need help with auxillary light switch
   / need help with auxillary light switch #1
Docwho
Howard, PA
New Holland/TC40
Hello
Need some help with wiring in auxiliary switches on a 2003 New Holland TC40. The switches have 5 blades.
Un-shore of where to bring in the power and what all of the blades are for. Please help!
need some good advise.
   / need help with auxillary light switch #2
Most multi-blade plugs have the post marked on the side of the plug or inside next to the plug. Without seeing it, it will be difficult to advise on what is what.
   / need help with auxillary light switch #3
Got Pics?
Way too may wiring options without a reference point.
   / need help with auxillary light switch #4
Sounds like they may be lighted switches or double throw but we still need to know what type and make. Diagrams are normally supplied by the maker. And as noted above, will be on the switch or available from the maker's website. Do a interweb search on the brand and model. There should be something. There are too many variables between brands and models to suggest universal connections.
Or you can do it the hard way and map the pin out yourself with a meter.
Thanks all
I figured it out. Front pin ground middle to pins power in, bottom 2 pins power out.
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
2019 Kenworth T270 Truck, VIN # 2NKHHM6X3KM358768 (A51572)
2019 Kenworth T270...
3 PHASE SEPARATOR (A52472)
3 PHASE SEPARATOR...
2022 New Holland Powerstar 110 Tractor with Loader (A51573)
2022 New Holland...
2024 BRAZOS  53FT ALUMINUM STEP DECK (A52472)
2024 BRAZOS 53FT...
