Need help with a hooper for tractor bucket
   / Need help with a hooper for tractor bucket #1
roermo
Hannibal MO.
4110 JD
Hi all, need some help: I am in Hannibal Mo, and as with many folks in the Midwest we are facing rising rivers. Here in Hannibal along the Mississippi River we have a flood wall that will turn back 31.2 or so. Back in 1993 our levee was bran new and the city and many folks worked 2 weeks straight bagging sand to put on top of the levee. It is looking like a repeat +.. Well 13 years later I am not sure I can put in that type of hard work.
I was thinking about my tractor and bucket could be put into use. On TV I have seen little clips of a tractor dumping sand into some kind of hopper then some how they load into bags.
Does any one here have plans or know how to build something that would hold a bucket of sand, then some how dump a measured amount for the bags. I have 4 foot bucket on a smaller tractor but this would be better than hand shoveling into bags. I thought I could strap on something to fill the bucket so it would only hold a couple of bags full of snad then dump in a hopper but thats a lot or repeat travel. So in closing is there a hopper design that will hold a 4 foot bucket of sand and then some how dispence it to the bags.
Any ideas.
   / Need help with a hooper for tractor bucket #2
The hopper could be just a standard grain hopper or even an old gravity box.
To meter out the sand at the same amount everytime would be a bit trickier.
One way to meter out the sand would be to mount a tube off of the bottom of the hopper. The tube would have to gates on it, one above the other. The gates would be set far enough apart to allow a certain amount of sand to be trapped between them. Start with both gates closed. Open the top gate allowing the sand to fill the tube. Close the top gate. Put the bag under the tube and open the bottom gate. Close the bottom gate and repeat the process. If you wanted to automate the thing you could add two pnuematic or hydraulic cylinders to the gates and 4 switches to know what the gate positions are. Add a couple relays and a pushbutton or selector switch and one guy could operate it while changing the bag. To hold the bag use a couple weighted arms and just slip the bag over the tube and under the weighted arms. The arms will need to be heavy enough to hold the bag with the sudden drop of sand.
   / Need help with a hooper for tractor bucket #4
I like the gravity wagon or cone hopper idea as mentioned above, with the use of the lower gate valve compartment. I would recommend adding some sort of tank vibrator to the side panel to help remove any bridging that might occur internally in the tank.
   / Need help with a hooper for tractor bucket #5
just a thought but mabey you and your tractor could be of more use helping place the sand bags that would certinly save some man power
   / Need help with a hooper for tractor bucket #7
Back when I was on active duty, the Seabee unit I was attached to here had to respond to flooding at the water treatment plant. We practiced every year with the MB-T2 Megga Bagger.
I don't think we ever hit the 3200 bags per hour it's rated at but I can tell you that going at half speed was a workout for the guy (gal) on the chute.
The key to the whole process is to have sand that is fairly dry. We had a supply stored on site that was covered.
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
2012 CATERPILLAR 316EL EXCAVATOR (A51406)
2012 CATERPILLAR...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
2013 FORD EXPLORER (A54756)
2013 FORD EXPLORER...
Utility Trailer (A52377)
Utility Trailer...
