Need Help With a FORD SELECT O SPEED
   / Need Help With a FORD SELECT O SPEED #1
SuperA
Bronze Member
Shawanagunk NY
FORD 4110 LCG , International 300 Utility, Farmall Super A, Farmall Cub
I Picked Up a 1958 FORD Select O Speed Model 981 High Crop that has a stuck Trani and need Help. I have been on all the other FORD Sites but have had no luck and Hope someone here can point me in the right direction. I Beliebve I have Narrowed down the Problem (I HOPE) to a Blown O Ring in the Feed Tube that goes into the Valve body in back. My Main Question is, Do I Have to Split the tractor just to put a new O Ring on there or is there another way??? The Pump is Definitely Working, Tube is Leaking and No Pressure is reaching the Valves. I have been Posting Videos on YOUTUBE, making a Journal of this if You care to watch My Channel name is MrDanoconnor thanks for Any Input at all. DanO
FORD 981 SELECT O SPEED REPAIRS: PART 7 - YouTube
Swict 72" Bucket (A50121)
Swict 72" Bucket...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A52748)
Kubota SVL65-2...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A52576)
2018 KENWORTH T680...
Case IH Farmall 75C (A52349)
Case IH Farmall...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
New Holland 824 2 Row Corn Head (A50774)
New Holland 824 2...
