travlitt
Platinum Member
- Joined
- Jun 12, 2012
- Messages
- 680
- Location
- Texas
- Tractor
- 8050C Branson, Branson 2400, 8N Ford, Round Fender John Deere 110, 3 60" ZTR mowers, a bunch of ride on mowers, 8' Brush hog , 15' Bat wing
I have a 16HP kohler 2 cylinder engine that runs on one cylinder. It has new plugs. Both cylinders fire when they supposed to. 1 cylinder makes power and the other one does not make more than 25% power. I checked the compresson on both cylinders and both of them have 120 PSI and will hold that pressure without leaking down. I can pull either plug wire off and there is lots of sparks on either plug.
I removed the double inlet muffler and the one cylinder has a lot of exhaust pressure and the other one has some but not much. Then from time to time the week cylinder will start making power at or near 100% but not full time.
What might the problem be?
