Need help with 54" blower on 1023e
   / Need help with 54" blower on 1023e #1
RxDoc
Johnstown, PA
John Deere 1023e
Just got a new 54" blower for my 1023e. I am having a problem installing the pto shaft under the tractor. When I have mmm lift all the way up I cannot get the shaft on the pto. It will hit the bar that connects the two draft arms. If I put mmm lift down I can run the shaft over the draft bar and everything connects fine. Is this the only way to get it hooked up?
   / Need help with 54" blower on 1023e #2
I don't think that you can have both mmm and snowblower connected at the same time at least not on the 2305. Why would you keep the mmm for snow removal. I think your better off removing it for winter and keep it away from salt and calcium. jmo.:thumbsup:
   / Need help with 54" blower on 1023e #3
Remove the draft bar.
I have the mower off the tractor it's just the lift kit for it that's giving me the issue. I guess I'll just have to remove the bar connecting the draft arms.
Just to give an update the dealer came out to have a look at it. Basically both draft arms and the bar have to come off. It's not to hard just one extra step when spring comes next year.
   / Need help with 54" blower on 1023e #6
Duh! I've should've known better. :confused2:
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A54313)
2016 INTERNATIONAL...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2014 Ram 1500 4x4...
EZGO GOLF CART (A50323)
EZGO GOLF CART...
2022 Big Tex 22GN-35BK+5MR 40ft T/A Gooseneck Equipment Trailer (A51691)
2022 Big Tex...
