NEED HELP- WIRING CABIN:INVERTER PROBLEM
   / NEED HELP- WIRING CABIN:INVERTER PROBLEM #31
   / NEED HELP- WIRING CABIN:INVERTER PROBLEM #32
Looking at the picture of your battery bank.. those battery cables look half as thick as they should be.
The wires in the pic is #4 UNDERGROUND trailer wire.They use it for feeding home entrance panels,including my 200 amp panel.They must be at least a quarter inch thick.Why are they not big enough to hook batterys togeather?
ALAN
HI ALL
The problem is fixed,inverter is working again.My wife and i drove up in the car,cause she knew id never stop talking about it.:D
I unhooked all the copper wires from the grounding panel,and isolated them from the white ones.Tryed it -still kicked to fault::(
Ichanged out the main breaker ,and back fed through a 30.Tryed it still kicked to fault.:( :(
I unhooked all the wires from the line coming in.Inverter stayed on:eek:
I moved all my coppers back with the whites,isolated the copper from the feed line.Tryed it-still kicked to fault::confused:
I unhooked the copper and let it hang in the air.Tryed it panel powered up,all worked fine:confused:
I will get some flack but i cut off the copper-PROBLEM SOLVED:)
All the outlets still have the extra ground protection,they are hooked up with the whites,which leads to the camp grounding rod.The generator is still grounded at the shed.Icant see that i need that wire for anything,unless mabey the cable underground should short or somethig?If that ever happens the inverter will kick,or the breaker on the generator should kick.Iaint worryed about it.Istill cant understand why it would work under generator power,but not inverter with that wire hooked up.:confused:
Every thing is working great under inverter power,including the new cieling fan in the cathederal ceiling.Im happy .Thanks for all the input
ALAN
2015 FREIGHTLINER M2 TANDEM AXLE 24FT FLATBED (A54607)
2015 FREIGHTLINER...
2004 Ford F-250 4x4 Service Truck with Liftgate (A53422)
2004 Ford F-250...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
2013 BMW 528i (A53424)
JOHN DEERE 3032E TRACTOR (A54756)
JOHN DEERE 3032E...
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A54815)
2022 McConnel...
