Need Help Using Three Point Log Splitter......
/ Need Help Using Three Point Log Splitter...... #1
Utopia Texas
Platinum Member
Brookshire & Cat Spring,Texas
Kubota B2650 / Kubota L6060 / Kubota ZD2300
I came across a hydraulic log splitter in my Dad's barn that he used to use on a Ford tractor where he could take the rear remote lever near the drivers seat and push it forward and then sideways into a notch which held the lever in the open position. Then the log splitter could be controlled at the splitter by way of the splitters lever. I have a NH 4.75 and there is no notch for my rear remote lever to keep it open. Can I use this log splitter on my tractor by holding the lever forward or back with a bungee chord or will this ruin something internal to the hydraulic system?
I hope my explanation makes some sense! Thanks...
/ Need Help Using Three Point Log Splitter...... #2
I do not have a 3PH log splitter but have read TBN posts that folks did exactly that by using a bungee cord or similar tied to something from the valve handle to keep it open.
/ Need Help Using Three Point Log Splitter...... #3
That is how you do it with a spring to center valve.
You have to bungee the lever open so the log splitter valve can operate the log splitter.
You could add a solenoid 3rd function valve and just flip a switch.
16ft. Terry Bass Boss Flats Fishing Boat w/ 18ft. S/A Boat Trailer (A66738)
16ft. Terry Bass...
1995 TIGERCAT 726 FELLER BUNCHER (A65056)
1995 TIGERCAT 726...
CATERPILLAR 249D3 SKID STEER (A65054)
CATERPILLAR 249D3...
1987 CAT D8N (A68134)
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2019 INTERNATIONAL 7400 SBA 6X4 DUMP TRUCK (A63276)
2019 INTERNATIONAL...
