Need help tracing wires after mouse had dinner - L5240
   / Need help tracing wires after mouse had dinner - L5240 #1
C4Ranch
Eastland Co, Texas
Kubota L5240 HSTC
Will try to post pic. I have a small loom near the starter with a single wire coming out and not sure where it goes.
There is a bigger loom above it that has a wire coming out that I think goes to fuel sending unit. Can anyone help confirm?
At the bottom of this pic you can see the loose wire coming out by the starter, no idea where it goes.
At top of pic you can see the big loom with a smaller loom coming out of it. Think it goes to the fuel sending unit since my gas gage stopped working but would appreciate if someone could confirm.
Thanks!
Bump. If someone could take the left side curtain off and peek at the wire terminations I would greatly appreciate it.
   / Need help tracing wires after mouse had dinner - L5240 #5
Can't you just match colors?
Yes for fuel sending unit, assuming mouse left anything left on the tank.
The wire by the starter I can't tell where it terminates to match anything...
   / Need help tracing wires after mouse had dinner - L5240 #7
C4,
I like your subject line. Some kind of critter has had dinner on my dash and chewed the wires off my idiot lights. I never figure out what they meant anyway so, I may not reconnect them.
   / Need help tracing wires after mouse had dinner - L5240 #8
The wire from the starter could have been going into the larger wiring harness. Just a guess but look very closely all the way around to see if the other end is inside the harness.
   / Need help tracing wires after mouse had dinner - L5240 #9
I don't know if you plan on doing any re-wiring. But if you do, I just stumbled upon this product, Posi locks for splicing wires. They also make Posi taps for tapping into wires. Both are sold on Amazon.
Good luck with the mouse problem. They just destroyed the air filter on the old lady's SUV.
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
2011 GR TRAILER GOOSENECK (A50854)
2011 GR TRAILER...
SCAN TO RECEIVE TEXT UPDATES (A51242)
SCAN TO RECEIVE...
1995 Olympian Generac 94A06155-S Generator (A49461)
1995 Olympian...
Caterpillar 60in Pallet Fork and Frame Attachment (A49461)
Caterpillar 60in...
2015 Chevrolet Silverado 2500HD (A51039)
2015 Chevrolet...
