Mid-Mount Mower Need help, tc24d mid mower deck removal
   / Need help, tc24d mid mower deck removal #1
dlmelton
london, ky
03 new holland tc24d
New member, first time post...
Bought a 2003 new Holland tc24d with a front end loader and a mid belly mower. I am trying to figure out how the mower deck comes off. I do not have nor can I fine a book on removing it. And the person I bought it from has no ideal either.
Only reason I want to remove it is because when I lift the rear hydro hitch up a down with a box blade on it the belly deck moves up and den to.
Any advise greatly appreciated...
   / Need help, tc24d mid mower deck removal #2
If you look under the tractor, towards the rear of the mower, there is a place to slide in a pin on each side to lock the mower up. The pins are approximately 3/8" x 6". To remove the mower, set the gauge wheels high, lower to the ground, pull the four pins on each corner of the linkage, and disconnect the PTO shaft. Since you have a loader the easiest way is to then lower the boom and pick the front tires of the tractor off the ground, and roll the mower out the front.
   / Need help, tc24d mid mower deck removal #3
Exactly!
2012 John Deere 7130 (A50120)
2012 John Deere...
Skid steer auger plate (A50322)
Skid steer auger...
2001 Nissan Frontier Crew Cab Pickup Truck (A51692)
2001 Nissan...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2003 Maverick Pathfinder 2200V Center Console Fishing Boat with T/A Boat Trailer (A50324)
2003 Maverick...
