Mid-Mount Mower Need help, tc24d mid mower deck removal
/ Need help, tc24d mid mower deck removal #1
dlmelton
london, ky
03 new holland tc24d
New member, first time post...
Bought a 2003 new Holland tc24d with a front end loader and a mid belly mower. I am trying to figure out how the mower deck comes off. I do not have nor can I fine a book on removing it. And the person I bought it from has no ideal either.
Only reason I want to remove it is because when I lift the rear hydro hitch up a down with a box blade on it the belly deck moves up and den to.
Any advise greatly appreciated...
/ Need help, tc24d mid mower deck removal #2
If you look under the tractor, towards the rear of the mower, there is a place to slide in a pin on each side to lock the mower up. The pins are approximately 3/8" x 6". To remove the mower, set the gauge wheels high, lower to the ground, pull the four pins on each corner of the linkage, and disconnect the PTO shaft. Since you have a loader the easiest way is to then lower the boom and pick the front tires of the tractor off the ground, and roll the mower out the front.
/ Need help, tc24d mid mower deck removal #3
Exactly!
