3-Point Hitch Need Help!! Smoking International 2424
   / Need Help!! Smoking International 2424 #1
gas69
Hardyston Twp., NJ
1954 Farmall Cub
I recently bought a International 2424 tractor with a 3 Piont Hitch... I was bottom plowing a field and the steering began to go away and the rear hitch was lazy coming up... I figured it was low on hydraulic oil... I added about a gallon and a half to the hydraulic resevoir in the rear and began to steer again, but I noticed it was smoking quit a bit now and it was blue... oil burning smoke... I wanted to finish the last few rows but I started to loose the steering again and the lift on the 3 point hitch... I had to leave the plow there as I couldn't lift it... and I manged to get the tractor back to the barn with hardly no steering but smoking up a storm... Is there any way the hydraulic oil can be entering the combustion chamber? I know years ago if a vacume brake booster was bad the brake fluid would enter the combustion chamber and cause it to smoke.... Any help would be greatly appreciated.. Thank you... Steve
   / Need Help!! Smoking International 2424 #2
Could be bad fuel- or rings, or valve guides, cracked head, blown head gasket, bad injector pump, or something else. Try draining and bleeding the fuel system first.
   / Need Help!! Smoking International 2424 #3
Check the crankcase oil level if it is considerably overfull most likely the hydraulic pump is leaking into the crankcase.
Ok.... I had checked the crank case in the morning, but never rechecked it...Yeah that sounds like a plan, now I guess I need to look and see what a rebuilt pump goes for and what kind of job to R & R it is.... Thanks I will let you know... Steve
   / Need Help!! Smoking International 2424 #5
Yes when the seal on the hydraulic pump goes it dumps hydraulic oil in the engine.
I R&R the hydraulic pump on my 424 the Ag version of your tractor and it is easy. If you get the 10 GPM pump they are more money, but the 7 or GPM is arounf $250. My diesel had the 10 GPM one.
Adams 5 ton Fertilizer Buggy / Wagon (A53472)
Adams 5 ton...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
UNUSED HURRICANE G350 PORTABLE CEMENT MIXER (A51248)
UNUSED HURRICANE...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
UNUSED AGT KRW23 WHEEL LOADER (A51247)
UNUSED AGT KRW23...
Year: 2012 Make: Mazda Model: Mazda3 Vehicle Type: Passenger Car Mileage: 141,080 Plate: Body Type: (A51694)
Year: 2012 Make...
