Need help running haydraulic hoses
/ Need help running haydraulic hoses #1
medic5221
Farmington, MO
Ford 5000
I have a 70 Ford 5000 that I just mounted a bush hog 2445 loader on. The loader came with a power beyond valve and an adapter plate. The tractor has a single spool valve on it. I put the adapter plate on and now the 3 point works only when I use the loader valve to raise the loader. As well my factory remotes do not work. I assume I have hooked up the hoses from the adapter plate and loader valve wrong. Can someone please help in routing the hoses the correct way. Any help would be greatly appreciated. Learning hydraulics as I go.
/ Need help running haydraulic hoses #2
Hello,
I think you switched the return and the power beyond line coming from the loader valve.
Check those two and post your result.
Wilco.
/ Need help running haydraulic hoses #3
All the valves should be in series, and the OUT ports should all go to tank. Any PB port will feed the next valve in series.
I switched the two hoses and everything works as it should. Thanks for your help.
Chris
2011 John Deere 9770 (A64119)
2011 John Deere...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
5' X 8' SINGLE AXLE UTILITY TRAILER (A64280)
5' X 8' SINGLE...
New Carbon Steel 4.75-12T Shackles, 38 Total (A62679)
New Carbon Steel...
2008 Ford E-450 Super Duty Ambulance (A61573)
2008 Ford E-450...
2003 International 4300 Flatbed Dump 571557 (A62613)
2003 International...
