Need Help Replacing Broken RTV 1100 Window
   / Need Help Replacing Broken RTV 1100 Window #1
curtisfarmer
Southern NH
M7040, L48, KX121-3, RTV 1100 and a couple of older Fords
Sure enough I started my lawn mower near my RTV 1100 and shot a rock through the window. Yay! I bought the window from Kubota $134, not bad. I need help on figuring out how to install it. It is a 2008 model with the full, non sliding glass. There is a rubber gasket that the glass fits into and then fits onto the door. I am also trying to get a Work Shop manual, there seems to be a million "free" downloads but I am skeptical.
Thanks in advance :)
   / Need Help Replacing Broken RTV 1100 Window #2
From what I have seen years ago, you put the gasket in the frame. Push a small rope <1/4" in the slot where the window goes. Start rope on either side at bottom then go around window so the rope will be in both sides & the top, not the bottom. Set the window in the bottom slot & push against gasket while pulling rope. This will allow one lip of the gasket to open to accept the glass. Make sure you keep pushing so glass will slide into the slot.
   / Need Help Replacing Broken RTV 1100 Window #3
Agreed...I'd also add a helper to keep constant outside pressure on the glass. A little soapy water in the rubber channel might help with seating the window.
USA ATTACHMENTS 24" EXCAVATOR BUCKET (A57192)
USA ATTACHMENTS...
405 (A52706)
405 (A52706)
EINGP PHT620 HAND PUSH ELECTRIC FORKLIFT (A57192)
EINGP PHT620 HAND...
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A53421)
2014 JLG G12-55A...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
