Need help removing throttle control lever -Removing rear hood. Ford 2000 3-cyl. gas
   / Need help removing throttle control lever -Removing rear hood. Ford 2000 3-cyl. gas #11
If I remember right, you need to remove bolt #9 completely out of part #6, as there is a notch in the control lever, to keep part #6 from slipping/turning on the shaft, once the bolt is in place.
I concur. Mine required removal of the bolt. The lower shaft was slightly bent which made it difficult to remove but it came out with some effort.
   / Need help removing throttle control lever -Removing rear hood. Ford 2000 3-cyl. gas #12
6-1/2 years later he's probably either got it or given up.
5K ANNULAR BLOWOUT PREVENTER (A50854)
5K ANNULAR BLOWOUT...
2006 CHEVROLET EXPRESS SERVICE VAN (A51219)
2006 CHEVROLET...
Lay-Mor Sweepmaster 400 Broom Sweeper (A49461)
Lay-Mor...
2019 CATERPILLAR D6 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2007 PETERBILT  385 CAB AND CHASSIS (A50854)
2007 PETERBILT...
2015 Ram 1500 Crew Cab Pickup Truck (A49461)
2015 Ram 1500 Crew...
