Need help removing shafts from the tranny on a g154 any help greatly appreciated!!
   / Need help removing shafts from the tranny on a g154 any help greatly appreciated!! #1
Gulkana
Bolens g154. Ford 3400 gasser, Massey M35 diesel
I've recently acquired a Bolens g154 2 cylinder and the long PTO shaft busted just behind the rear gear. I need to know how to get it out and the new one in. I have split the two cases and I am not wondering how to remove the shafts above the bottom long PTO shaft? I have a press and can press them out but I am not sure from which side and exactly how to go about it. 60445851201__1F5F6596-686C-4134-A4ED-6835905B0D28.jpeg60445854144__AAEED575-0E58-49FD-974F-DCBE3CE89858.jpeg60446150379__1A0342DC-5AC6-4F41-ACB9-69E3A6953FB8.jpeg60446151435__14C42220-D24C-4C1A-B171-C72E3EACF70C.jpegIMG_2976.jpeg Any help would be great!
i have looked hither and thine and studied the thread you mentioned. It has been a big help. However he doesn't show how to REMOVE the shafts from the tranny. I have searched and searched and studied the service manual I have and no where I have found shows how to do this. I reckon a transmission person would know. I am not a transmission person. I am an engine guy. SO this is new territory. The bearings are in good shape and I would like to pull the shafts without pulling the bearings.
Thanks for the reply.
   / Need help removing shafts from the tranny on a g154 any help greatly appreciated!! #4
Check ilovetowork55 s YouTube channel.
I'll get my manual out of the shop and take a look tonight too.
Success! I managed to figure it out. A little complicated. You have to press out the shafts from the bearings in such a way to be able to remove the shafts. Helps to have a press! In fact I wouldn't attempt this without owning or borrowing one.
It took some figuring. New PTO long shaft in and so far so good. iF anyone ever has any issues with something similar, tranny or PTO shoot me a message. I have lots and lots of reference pictures. There is absolutely no way to remove the PTO long shaft from the cases without splitting, tearing down the tranny shafts and gears and pressing out almost all of the bearings. I had heard tell someone said you could pull the long shaft out the back of the case.. uh no.
   / Need help removing shafts from the tranny on a g154 any help greatly appreciated!! #6
Cool! Congrats.
   / Need help removing shafts from the tranny on a g154 any help greatly appreciated!! #7
I'm glad you got it as the manual is hard for me to follow. Other than that there are c clips on many of the shafts it makes no mention of how to remove the bearings. I hope if I get to a repair like that it makes sense.
2000 JLG 600AJ ARTICULATING LIFT (A55745)
2000 JLG 600AJ...
MILLERMATIC 251 W/LEADS (A55745)
MILLERMATIC 251...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
Deere 35P (A53317)
Deere 35P (A53317)
2016 Isuzu NPR Landscape Dump Truck (A51692)
2016 Isuzu NPR...
199049 (A51243)
199049 (A51243)
