Need help putting on my Hydrolic lines on my loader John Deere 2520
   / Need help putting on my Hydrolic lines on my loader John Deere 2520 #1
Trav City
Canton and South Boardman, Michigan
2011 John Deere 2520
Hello, I'm trying to put the two lift lines on and it appears over the winter the hydraulic must have settled in the cylinders creating pressure at the end and now I cannot get the lines on. The bucket tilt lines went right on. I remember reading this issue on here before and thinking I never had that problem, now I do and cannot find the thread. thanks
   / Need help putting on my Hydrolic lines on my loader John Deere 2520 #2
Wiggle all the hyd valve levers with engine off.
Take the male QD and push it against a hard surface, using a rag to cover the QD.
Use a brass hammer to tap the ball or poppet to release some fluid.
   / Need help putting on my Hydrolic lines on my loader John Deere 2520 #4
To avoid this in the future, do as JJ suggests and move the control handle around with the engine off before you remove the lines. This will depressurize them.
Bill
Thanks Bill, I usually do that before I diconnect them with all attachments. Maybe I forgot last year. I am going out this morning to try it again. I will let you guy know how it goes. Thanks for the suggestions.
   / Need help putting on my Hydrolic lines on my loader John Deere 2520 #6
If it is sitting in the sun , that can build pressure also .
Got it. It still wasnt easy, but I made sure the fittings were clean and released the pressure a bit in the lines and finally got it. Thanks to all that took the time to help and make suggestions.
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2013 INTERNATIONAL 4300 26 FT BOX TRUCK (A51222)
2013 INTERNATIONAL...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A50397)
1989 Freightliner...
Rhino FS15 Flex-Wing Rotary Cutter - 15 Ft Heavy-Duty Brush Hog for Pasture and Roadside Mowing (A52128)
Rhino FS15...
2019 CATERPILLAR 315FL CR EXCAVATOR (A51242)
2019 CATERPILLAR...
2001 DITCH WITCH 8020 RIDE ON TRENCHER (A51242)
2001 DITCH WITCH...
