Need help purchasing a Tractor
/ Need help purchasing a Tractor
SSDoxie,
Thanks for that input. You make a very valid point that I did not really consider. Actually, after further consideration not only will some of those attachments be fairly heavy for the tractor, the tractor will not have the hydraulics to run some of them (like the rotary cutter).
I was hoping that most of the attachments would interchange but alas, I don't think that's going to happen.
Chiefs Fan
/ Need help purchasing a Tractor #22
You could use a PTO driven hyd pack and run lines to the front to run the RC (if you can make a hook up system).
I agree that all implements won't work. A tractor is pretty universal for future implements. Can't get much more standard that QA and 3PT hitches.
/ Need help purchasing a Tractor #23
Gentlemen, thanks for all the input. Point well taken about mowing the lawns........I have a small Garden Tractor for that and it makes sense to keep using that and use the tractor for all the other stuff.
Does anybody have any input about must have options?
Thanks in advance.
Chiefs Fan
get rear remotes, I wish I had
I will be getting them soon
Gentlemen, thanks for all the help. I am quoting out a few tractors right now but it looks like I will be going with the CT335.
For Sale L4479 Snowblower and Subframe
For Sale L4479...
UNUSED AGT ATK- TC 24 TIRE CHANGER (A64281)
UNUSED AGT ATK- TC...
2019 Ford F-150XL (A64119)
2019 Ford F-150XL...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
