Need help picking a garden tractor
/ Need help picking a garden tractor #1
finnfarmer2
Southeast
Kioti CK35 HST
First post, been lurking for a while. It's time for us to buy a companion to our compact utility tractor. We need a garden (yard?) tractor that is capable of mowing grass, pulling implements such as an aerator or a seeder on the pasture/meadows. Most of our property is wooded, so we need something that we can use in the woods riding along tractor trails picking up wood debris, firewood etc. Our clear cut pastures are about 4 acres total with slopes. Our two meadows have big trees on them and have steeper hills than the pastures, total area about 3 acres.
We thought about using the CUT tractor for all of this, but found it to be unpractical (too heavy=leaving imprints, need something to turn easily in tights spots, not designed for mowing etc.)
What would you recommend? Looking at a Craftsman Pro Series 54" 26 HP, however it's kind of pricey $3,000, would like to stay in the $2000-$2500 range.
Thanks!
/ Need help picking a garden tractor #2
Thanks!
Your price range is too low for a quality garden machine. Need to go up to 5 or 6k.
/ Need help picking a garden tractor #3
I found a Bolens GT 1453 garden tractor on Craigslist for $650. Came with a mid-mount mower deck (48" wide) and a 33" wide rototiller.
Used it mostly to till the veggie garden. After 4 years I replaced the ailing Tecumseh engine with a $350 Predator engine (420 cc, 13 hp, Honda clone) from Harbor Freight.
New garden tractors are pretty expensive ($4K plus).
Good luck.
/ Need help picking a garden tractor #4
I'd agree with other posters about your price range for a new decent machine. Your best hope would be to find a machine like flusher's. I've got a 33 year old Case 18 HP that I've retired from extended hard work. They are out there, but you had better get ready to do some serious parts searching and wrenching to maintain one....unless you are extremely lucky. :2cents:
/ Need help picking a garden tractor #5
G'day Mate and welcome to TBN from Downunder.
If you're happy with the level of support from your Kioti dealership, I'd talk with them about your needs. They may cut you a deal due to being a repeat customer, although you may have to talk with a different salesperson as SCUTs and above are usually separate sales from 'Lawn Tractors' & mowers. They may have something that's been "previously loved" to suit your requirements.
Enjoy the site.
/ Need help picking a garden tractor #6
The first time I tried a zero turn was the last time I considered lawn tractors. This was just a cheap zero turn but it runs circles around the green lawn tractor I used to buy every few years. They will still pull things just fine but mow much faster.
There are certainly nicer one in the 6k range available that are more commercial quality but you can mow a lot of grass with a 2.5k or 3k zero turn. This is probably a good time to buy a mower.
/ Need help picking a garden tractor #7
The sure way to know the garden tractor has a heavy duty transaxle is if the rear wheels use five bolts to hold each of them on. Under no circumstances purchase a lawn tractor with a K46 transaxle unless it's for a small level lawn and plans for using the tractor for more than 200 hours in it's lifetime.
Thank you for all the replies! Unfortunately, our budget is tight this fall as we need to buy a chipper and a stump grinder. I might have to start looking for a used one, even though I do not like to buy other peoples problems (my experience).
Good comment about staying away from the K46 transmissions. That's what we figured as well, the garden tractors we've been looking all have the K58 transmission.
We found a great clearance deal on a Craftsman Pro 50" 26 HP and brought it home. This one is identical to the 54" we were looking at earlier, but $900 cheaper fitting our budget and needs perfectly. Thanks again for all the replies. Now off to getting a new chipper....
/ Need help picking a garden tractor #10
You will likely be very happy with your choice. Great machine!
/ Need help picking a garden tractor #11
I see a lot of Craftsman lawn tractors all around. Some that I know of have had lots of hours and keep on going...however I'm not aware of the model # involved..
Good Luck with your plan. BTW, one can spend a chunk of change on a chipper. Decisions .....Decisions.
/ Need help picking a garden tractor #12
I know the OP already bought but for anyone looking in the future.. an older used kubota rider is a great deal. They have the reliable Kubota diesel and you can buy them fairly low hours for under $3k. Very heavy built. Not sure why more people don't buy those over crappy box mowers. I doubt he will be happy but hope I'm wrong for his sake. I had a crapsman bought it new and had it in the shop 3 times the first year... just mowing grass with it. I finally called Sears and said your getting your mower back Period.. they gave me 80% of what I paid which I felt lucky to get for that POC.
2022 EZ-GO ELITE...
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
2011 FORD F-150 (A65643)
2011 FORD F-150...
2020 JOHN DEERE 333G SKID STEER (A65053)
2020 JOHN DEERE...
New/Unused ATS Electric Jack (A65583)
New/Unused ATS...
Carryall 1700 4x4 (A61574)
Carryall 1700 4x4...
