Need help on trusses 9' on center or 4' on center for pole barn
   / Need help on trusses 9' on center or 4' on center for pole barn #1
Cedar Point
Sandusky
John Deere
Should I go with a truss span of 9' or 4' span? Every company says different things.
   / Need help on trusses 9' on center or 4' on center for pole barn #2
Depends on snow load, wind load, roof weight, etc. Around Lake Erie and what I have seen, if the price is not too much more, depending on the size of the structure, I would go 2 foot on center. One barn we have is 4 foot on center and the house addition is 2 foot on center. Should have gone with 16 inches on center for the house for a more rigid roof frame. The additional trusses on the barn would not have been much more, and 2 foot or 16 inches on center would have been nice. Especially with the quality of wood available for trusses these days and the common use of 7/16 OSB for a shingle roof on many smaller barns.
   / Need help on trusses 9' on center or 4' on center for pole barn #3
I never quite understood 9 feet since it's an odd number. I think the choice is between 8 feet and 4 feet. Either works. 8 feet will be cheapest. If you ever intend on insulating and installing a ceiling, go 4 feet. Liner panel can span 4 feet but not 8.
Thanks - 40x64 14' tall metal roof. Posts or laminated beams?
   / Need help on trusses 9' on center or 4' on center for pole barn #5
Are you putting the posts/beams in the ground (set in concrete, of course) or something else (posts on top of concrete pillars, foundation) etc?
   / Need help on trusses 9' on center or 4' on center for pole barn #6
the truss can be designed to carry the same load either spacing, basically the spacing would have to deal with the purlins, used, and the size of them to carry the loads, so if cost is the issue figure both roof systems to make your decision,
some may also consider the ease of putting up ceiling materials, if desired,
I like to see some closer spacing my self, (OK it seems like if you have wide spacing and failure would occur disaster happens, but on closer spacing one can fail and the others help support until repair can be accomplished many times),
My two cents,
Don't you have to lay a purlin on its edge on a 9' application. How would you get a good grip on your metal roof...?
   / Need help on trusses 9' on center or 4' on center for pole barn #8
Yes, roof purlin on edge for 8 or 9 foot spacing, flat for 4 foot spacing. Supports the roof fine either way but you have less of a "target" for the screws if they are vertical.
   / Need help on trusses 9' on center or 4' on center for pole barn #9
For what it's worth I would not go less than 4' O.C. especially with the 14' walls, think in the long term. Good luck.
   / Need help on trusses 9' on center or 4' on center for pole barn #10
If the snow and wind load ratings compare favorably, it doesn't matter. Pole barns are not 200 year structures no matter how much lumber is used.
UNUSED CFG INDUSTRIAL STSD10 QUICK ATTACH SEEDER (A51244)
UNUSED CFG...
2020 Ford F-250 Ext. Cab Pickup Truck (A50323)
2020 Ford F-250...
2019 CATERPILLAR 308 CR EXCAVATOR (A51242)
2019 CATERPILLAR...
2015 Ford Transit 250 Cargo Van (A50323)
2015 Ford Transit...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
