need help on st1620/d1650
   / need help on st1620/d1650 #1
texas
satoh st1620 4cyl diesel
hello i have a mitsubishi/satoh st1620 i think its the same as the mitsubishi d1650.it has the 4cyl diesel engine.satoh says it is 16hp and the mitsubishi says it is 20hp.are these tractors the same mine is white with a grey frame and the mitsubishi is blue with a black frame side by side they look the same to us. just needing to know what wix filter for the engine oil and how much does the crankcase hold. also how do i check the oil in the transmission and what oil does it use gear oil or hydraulic oil i see one oil cap filler just in front of the seat that says oil. sorry for so many questions, just got the tractor and i know nothing about it. just in bad need of some help. thanks so much for ya'lls help.
   / need help on st1620/d1650 #2
Valley Power
your best bet is to call valley power .you would have your questions answered plus you could get a manual for your tractor for about 50 bucks .it would be worth it if you would be maintening your tractor.get the number from the above link.
   / need help on st1620/d1650 #3
They are the same tractor.Who says they are different HP?
thanks for the help. i had another person tell me that about the hp. thanks again
   / need help on st1620/d1650 #5
I would suspect both HP figures are pretty much correct, just depends on how you want to rate it.... 16 PTO HP and approx. 20 engine HP.
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
Enmark Z Spray (A53316)
Enmark Z Spray...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A59823)
1987 CATERPILLAR...
1981 LINK BELT HSP 8028 (A58216)
1981 LINK BELT HSP...
2015 Ford F-250 Crew Cab Pickup Truck (A59230)
2015 Ford F-250...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
