Need help on my Ford 641 tractor
   / Need help on my Ford 641 tractor #1
MillWeld
Durham NC
Ford 641
I converted my Ford 641, gas, 134 cu in) to 12 VDC about a year ago and that was the best thing I have ever done to it. I did not change the solenoid switch or the starter - they are still 6 VDC - because most on line instructions indicated that was OK. It starts in anout 0.25 seconds so I figured those units will be overpowered for such a short time that it won't matter. OK - a few days ago I was mowing, shut the tractor down to replace the clothes line, tried to restart and it was like someone had removed the battery - no sound at all. Tested the batt. It was OK. Tried my truck battery anyway (just in case) . No sound either. I replaced the solenoid w/ another 6 VDC unit (used) and got a very slow crank but not enough to start it. I hot wired the starter motor and got the same very slow crank but no start. The starter turned so slow it was worse than I experienced with it when I had a 6 VDC battery. I have a 12 VDC solenoid on order but haven't received it yet. Doubt that will help since hot wiring didn't work. Is my starter bad? Ideas?
Bob
Solved the problem this AM. I replaced the solenoid w/ a 12 DVC and it started. ?????
Bob
WOLVERINE PAB-11-72W HYD QUICK ATTACH ANGLE BROOM (A51244)
WOLVERINE...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
2016 FORD F550 CREW CAB SERVICE TRUCK (A52141)
2016 FORD F550...
2022 JOHN DEERE 85G EXCAVATOR (A51242)
2022 JOHN DEERE...
SELLICK S80J4E-2PS ROUGH TERRAIN FORKLIFT (A51242)
SELLICK S80J4E-2PS...
UNUSED MOWER KING SSAB72 ANGLE BROOM (A51244)
UNUSED MOWER KING...
