Need help on my Ford 641 tractor
   / Need help on my Ford 641 tractor #1
MillWeld
Durham NC
Ford 641
I converted my Ford 641, gas, 134 cu in) to 12 VDC about a year ago and that was the best thing I have ever done to it. I did not change the solenoid switch or the starter - they are still 6 VDC - because most on line instructions indicated that was OK. It starts in anout 0.25 seconds so I figured those units will be overpowered for such a short time that it won't matter. OK - a few days ago I was mowing, shut the tractor down to replace the clothes line, tried to restart and it was like someone had removed the battery - no sound at all. Tested the batt. It was OK. Tried my truck battery anyway (just in case) . No sound either. I replaced the solenoid w/ another 6 VDC unit (used) and got a very slow crank but not enough to start it. I hot wired the starter motor and got the same very slow crank but no start. The starter turned so slow it was worse than I experienced with it when I had a 6 VDC battery. I have a 12 VDC solenoid on order but haven't received it yet. Doubt that will help since hot wiring didn't work. Is my starter bad? Ideas?
Bob
Solved the problem this AM. I replaced the solenoid w/ a 12 DVC and it started. ?????
Bob
72in Rock Bucket Skid Steer Attachment (A50322)
72in Rock Bucket...
Road Brute Flat Deck Trailer (A50514)
Road Brute Flat...
2013 Jeep Patriot (A50324)
2013 Jeep Patriot...
1996 PETERBILT 357 35 TON WRECKER (A50505)
1996 PETERBILT 357...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2020 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
