Need help on fuel gauge
   / Need help on fuel gauge #1
Spuddozer
Marshall, IL
New Holland TC 35d
I have 04 TC 35DA an the fuel gauge is way off. Is there and adjustment or any way to make it read closer to what it has in it? At least there is more in tank than shows. Thanks in advance.
   / Need help on fuel gauge #4
The connections are easy to get to on the tank. There is not an adjustment that I know of. I just changed the sending unit in my Boomer 8N except it was the opposite, it showed more than was there. Would run out of fuel showing 1/4 of a tank. Was the cheapest to start with compared to a gauge cluster.
The TC series and my Boomer 8N use the same sending unit, was $104.34 plus I bought a new gasket for $5.20 from Messick's, plus shipping. It's easy to change, 2 screws hold the cover in place and 5 screws hold the sending unit in place. One wire has a ring terminal connection with a screw in the middle and one wire has a slide on spade terminal connection.
Object moved
Click on 02.03 Engine Equipment - Fuel Tank
NEW Wolverine Skid Steer Pallet  Fork Hydraulic Adjustable (A59000)
NEW Wolverine Skid...
New/Unused Pallet of Ground Protection Mats (A57454)
New/Unused Pallet...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A56435)
2017 Cadillac...
New/Unused SD Lanch 20x20 Carport (A57454)
New/Unused SD...
3PT HYD HAY FORK (A52708)
3PT HYD HAY FORK...
2006 Ford Taurus SE Sedan (A54815)
2006 Ford Taurus...
