Need help on a Long 360 power steering
   / Need help on a Long 360 power steering #1
Rebeldad1
Hughett Bend Washington
Kioti Tractor, John Deere Mower,New Holland Mini Excavator
I am purchasing a Long 360 that the power steering doesnt work on. Can you tell me how it works and how to determine why it doesnt work?
Thanks!
Is this the best place to look for Long tractor information?
   / Need help on a Long 360 power steering #2
Is this a Romanian tractor if so does it have a PS pump or does it use the hyd pump?
   / Need help on a Long 360 power steering #3
This is an LS model . Can not be too serious,possibly low fluid, or at worse a bad pump. According to the specs I have reading right off of them it has a hydrostatic system,with 2 pumps. One is the implement pump at 8.1 gpm and the steering pump is 4.1 gpm. I am not sure if it is a gear or belt drive. Either way it could be something simple. Like I said earlier the worst it could be would be a bad pump. Any Montana or LS dealer should be able to help you.
   / Need help on a Long 360 power steering #4
Is this tractor a Romanian Long 360 or a Long Landtrac 360 made in S. Korea? They had both.
   / Need help on a Long 360 power steering #5
Sorry,I guess I stuck my foot in my mouth. I was just aware of the Ls model. I did not know they made both.
   / Need help on a Long 360 power steering #6
No you did not. This is what tractorsbynet is all about and why this is such a great site. Alot of input from people that have been there. Wampum hit the nail on the head in the above post. I can add a little more. The suction pipe feeds oil to both power steering and hydraulic pumps, that feed 3 pt. hitch and remotes. If they work, than oil is getting to the area of the pump. The next steps are alittle more complex and very dangerous to the layman. The system may have to be flow rated to continue troubleshooting. Quality dealers have special equipment to do this safely. You could start replacing parts, but this may not prove cost effective. This problem is rare to these units. I had one steering orbital fail on a new tractor, but nothing else. Wish I could add more. Good luck trac
2017 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2017 Dodge Ram...
(2) ALEMITE GREASE HOSE / REEL & NOZZLE W/ GAUGE (A51244)
(2) ALEMITE GREASE...
2020 BROCE BROOM RCT350 SWEEPER (A51242)
2020 BROCE BROOM...
CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51243)
CASE IH 580...
2018 Ford Escape SE AWD SUV (A50324)
2018 Ford Escape...
