Need help. No water.
/ Need help. No water. #1
N80
Super Member
SC
Kubota L4400 4wd w/LA 703 FEL
Down at my cabin for a week vacation of hunting and projects and now have no water and can't figure out why. This is what happens:
Turn faucet on and water runs, slows down, stops. A minute or so later it comes back on.
Watching the pressure gauge on the tank under the cabin it will cycle normally once or twice. It seems to be set between around 28 and 20. In other words, cycles on at 20, cycles off somewhere above 25. Then it will drop down to 20 and then suddenly drop to 0.
Breaker has not been tripped.
At the well head everything appears normal including the big black snake in the little pump cover. No frayed wires etc.
Any advice? Worried this is going to ruin my vacation.
Any help much appreciated.
/ Need help. No water. #3
Is the pressure switch clean? I had a spider build a nest in one a few years back that caused me all kinds of issues until I figured it out, pretty obvious as soon as you pull the cover off if there's anything in there.
/ Need help. No water. #4
If your gauge says that you have 20 pounds, there should be water at the tank. I would open up the line as close to the well as possible and make sure water is coming out.
Then it's just a matter of working your way along the line to see where there is water and where there isn't.
/ Need help. No water. #6
Great advice!
+1 on the flakey pressure switch and/or a clogged line to the pressure switch. It happens every couple of years here. The switches are pretty cheap, so I have taken to replacing them rather fiddling with them to get another year or two out f them. Once there is rust or gunk at the diaphragm, the party is basically over.
I would start by turning the power off, and looking inside the pressure switch cover, checking the contacts for spiders :))thanks @sea2summit!) and general corrosion. Inside the cover should be a diagram on how to raise the pressure. Turn the screw to raise the pressure a bit. If that fixes it, great, if not, power off, and then loosen the coupling at the pressure switch and see if water flows freely out of it. If it has crud, or rust in it, clean out the line and the fittings, or replace them, remembering to clean things out at the pump, too.
All the best,
Peter
/ Need help. No water. #7
If the pressure switch is turning the pump on at 20, it should be turning it off at 40. I think the overload in the motor is tripping at like 28 before the tank is full. Then it takes a minute or so for the overload in the motor to cool down and reset. During that time the pressure goes to zero. New control box and pressure switch is a good place to start. But I am afraid a new pump/motor is in your near future.
/ Need help. No water. #8
I believe your pump is going out. With the faucet on it should run until the faucet is closed. You can rule out the pressure switch by bypassing it and connecting your leads together. Just shut off your breaker. Wire the leads together, open a faucet and flip the breaker. If water runs like it should and doesn’t stop you have a bad pressure switch. Also if it is dropping to zero you may have a bad check valve.
  • Good Post
Reactions: JJT
Update:
Pressure switch looks fine from the outside.
Got voltage all the way out to the well head.
Tank has about 18-20 pounds of pressure when empty so tank is okay.
Removed pressure switch and it is gunked up and rusty looking inside. Waiting for wife to get back with new switch.
Still some unexplained weirdness though. The switch started staying in the On position regardless of the pressure in the tank. Earlier it was functioning some but now staying in the On position. With the breaker On the water would run and then stop even with the pressure switch stuck in the On position. After a minute or two it would come back on again. Then stop. When this was happening their was no change in voltage at the well head. I can't explain that unless there is an overload feature on the pump as @Valveman suggests......but this cycling on and off would continue to happen with the faucet at the well head open. Not sure why the pump would overload with the tap open.
My brother-in-law was here. He's better at this stuff than me. He is stumped. He called a plumber friend. Went through the details and he at first thought it might be the pump but ruled that out and suggested we see if the switch was gunked. Which it is.
Wife is taking forever to get back from town but will let you all know what happens with the new switch installed.
/ Need help. No water. #10
N80 said, "In other words, cycles on at 20, cycles off somewhere above 25. Then it will drop down to 20 and then suddenly drop to 0."
Sounds like to me that your check value in your well pump is not working and it's letting the water in the pressure tank flow back into the well, or you may have a water leak in your system somewhere.
And if your pump is shutting down at 25 pounds of pressure, then maybe it's hurting a lot also.
KC
Replaced pressure switch. Switched on the breaker. Tank fills. Pressure comes up to 40. Pressure switch still DOES NOT turn off. Just sits there at 40 psi but switch stays on. Open the tap and it runs like gangbusters for a minute then stops. After a minute it starts to run again. Same as before.
Can't figure why the pressure switch will not open (turn off) at 40 psi.
Wonder if there is a hole in the hose pipe down in the well that only leaks at a certain pressure.
Going to pull the pump. It is 250 feet down.
/ Need help. No water. #12
If the pump wasn't already off, the pressure would keep climbing and not stop at 40 or 28. I think 40 is just a coincidence and it is turning off because the internal auto re-setting overload in the motor is tripping. Waiting a minute or so and the water just magically coming back on is a clue. The overload resets itself in about a minute and water comes back on. Put an amp meter around one of the hot wires and you will see the amps peg, then drop to zero as the pump shuts off. But you will have 240V on all the lines the entire time.
Not much you can do when this starts happening except to replace the pump/motor. They make those auto-resetting overloads so you don't know you have a problem until it is too late. With the old push button overloads in the control box, which they still use on 2HP and larger, at least you know the first time the overload trips.
Planned obsolescence is built into pumps and the auto reset overload helps promote cash flow at the pump manufacturers. Pumps come with about 7 years worth of on/off cycles built into them. The bladder/diaphragm in the tank last about the same. If your pump doesn't go out from the normal on/off cycling in 7 years, the tank bladder fails and hurries it along. The auto-reset overload has probably been tripping occasionally for a long time, you just didn't notice. By the time you start to notice it is too late to save the pump.
Submersible pumps are completely frictionless when up and running. They are made for continuous duty. I have one that hasn't turned off since the year 2000. The bearings are only dry on start up, so the more starts the less time a pump will last. When you get a new pump make sure this doesn't happen again by installing a Cycle Stop Valve which can more than triple the life of the pump and everything else in a pump system.
/ Need help. No water. #13
@N80 So, your setup is a submersible pump 250' filling a pressure tank at the surface?
With the faucet open, do you ever get air out of it? Have you checked to see if the pump is shutting itself off, even though the pressure switch is on? (Current drops to zero, or the voltage changes)
If your pump isn't shutting off, and there pressure is stable, then either you have a leak in the pipe, or your pump is worn and can't build pressure beyond that point, or your well has run dry and the pump is shutting itself due to overheating. If you have eliminated above the well leaks, then yes, it is time to pull the pump. Sorry.
All the best,
Peter
Update: It was the pump. Or, now that the new pump is in, everything is working.
There was nowhere in this county to buy a pump but my brother-in-law knew a recently retired plumber with a small warehouse behind his house and he just happened to have a pump. We got it in just before dark. Don't know how much it costs but I used to rabbit hunt with this old retired plumber. We visited a while a talked about our rabbit hunting days. My brother-in-law told me up front that the pump would cost more than the big box stores but I don't care. I'd rather pay too much for one from a local fellow than a cheap one from the big box store. Plus it was only 8 miles away rather than 50.
I sincerely appreciate the help from you guys. It helped us sort the problem.
Most of a vacation day down the drain but the rest of the week salvaged.
/ Need help. No water. #16
Good to hear it. I've been reading from the start but adding my 2 cents wouldn't have been worth the zinc it's made from.
Now that you have that fixed, I hope you are able to enjoy the rest of your week. 👍
  • Good Post
Reactions: N80
Thanks. Not the way I wanted to spend a vacation day. But as always down here it was interesting to see how small rural communities work. In addition to my brother in law and the retired plumber, two very competent neighbors came by to help. All the tools we needed right at hand.
A big part of why I like to hang around down here I suppose.
/ Need help. No water. #19
I just spent the last two weeks trying to get my shallow well pump working... pressure came right up when I first tried it but I had a bad leak so had to start over. It wouldn't build pressure, and I'd mess with it but it still wouldn't build pressure... I was already to start digging the 250 foot water line up but tonight I decided to just let it run and lo and behold- it ran and then shut off! It turns out that the gauge was no good.
/ Need help. No water. #20
How did you pull the pump and 250' of pipe?
