Front-End Loader Need help! Model 91 FEL fell off prop rod.
   / Need help! Model 91 FEL fell off prop rod. #21
I made certain to clean the fittings thoroughly prior to reconnecting.
I can raise the bucket without any issues, but when I try to tilt down I must have someone physically push down on the bucket. Once the bucket is pushed down, it will only then tilt back up hydraulically.
Why not swap the curl and boom cylinder couplers, should help you determine whether the problem is with the valve or hoses and cylinders.
   / Need help! Model 91 FEL fell off prop rod. #22
your hoses are either on wrong or one of them is not on all the way. Is the hyd pump "laboring"?
my neighbor had a problem with his tractor getting slower and slower with less power and the curl not working correctly. He had one hose not connected completely. The hyd pump was loading up. It is a good thing he asked for help when he did.......... and this guy is an "engineer"
   / Need help! Model 91 FEL fell off prop rod. #23
I think DeadHorse is right. You have a hose that is not connected all the way. Good Luck and keep us posted
You guys nailed it! I have one hose that is not connected firmly. I can attach any 3 of 4 hoses, but the 4th one will not attach.
Problem is...I cannot (no matter how hard I push) get it to seat completely. It keeps seeping hydro fluid into the coupler every time I try to push it on, creating a hydro-locking force that prevents me from pushing it on completely?
What to do now???
   / Need help! Model 91 FEL fell off prop rod. #25
If its the male end try pressing the ball against a flat surface to let of the pressure the try it. Use a shop rag or some towels to keep from making a big mess with the oil. Good Luck
The hoses are female. I'll give a go at relieving the pressure.
   / Need help! Model 91 FEL fell off prop rod. #27
Yes, relieving pressure is probably the cause. I have this issue with my rear remotes from time to time.
Chris
Relieving the pressure did the trick! :) Thanks all!!!!!
   / Need help! Model 91 FEL fell off prop rod. #29
when you take the FEL off the tractor you have to relieve pressure in both circuits before you disconnect the hoses. Once the loader is sitting on the stand (or its fold down legs) and disconnected from the tractor, with the tractor engin off, "stir" the FEL control, gently. THEN disconnect the hoses and back the tractor out.
The same thing can happen to any Hyd driven implement. You can even do it to a splitter.
"Axe" me how I know............
Will do! Thanks.
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2010 Hyundai Elantra Touring Sedan (A54815)
2010 Hyundai...
Two Pairs of 10ft Fork Extensions (A53421)
Two Pairs of 10ft...
2007 Ford Five Hundred SEL Sedan (A54815)
2007 Ford Five...
2018 Ford Escape SE AWD SUV (A55853)
2018 Ford Escape...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
