Front-End Loader Need help! Model 91 FEL fell off prop rod.
   / Need help! Model 91 FEL fell off prop rod. #1
1FAST12R
Perry County, PA
Kubota B8200 HST 4x4
The prop rod I was using for my Model 91 FEL was too long allowing it to topple off it. No damage to the FEL and it somehow managed to stay upright.
Any suggestions how to get this FEL off the ground and back onto my tractor?:(
My tractor is a Kubota B8200HST.
   / Need help! Model 91 FEL fell off prop rod. #2
Can you borrow a large A-frame and winch it up a bit? Without seeing how it's sitting on the ground, I can't offer much more advice other than to maybe invite a bunch of friends/neighbors over and have them manually position it to where you can drive into it again.
   / Need help! Model 91 FEL fell off prop rod. #3
Without seeing pictures it's hard to offer suggestions. Any trees close you can rig to? Another tractor you could borrow?
Pizza, Beer, and friends sometimes works in these situations also;)
   / Need help! Model 91 FEL fell off prop rod. #4
If you can't find another tractor to borrow, maybe you can borrow a boompole or, as a last resort, buy one. I think you would have enough lift on your 3PH to get the loader arms back up so you could prop it up again. Be careful and don't get under anything until you have it stabilized.:)
   / Need help! Model 91 FEL fell off prop rod. #5
Scissor jack from your car, maybe two. Lift it one foot at a time and support it very well each step of the way.
OK here's pics of my FEL on the ground and my tractor.
   / Need help! Model 91 FEL fell off prop rod. #7
Get a floor jack and some 2x6's. Then put the floor jack under the orange cross beam just behind the bucket in the last picture. Jacking that up will fulcrum the connecting end of your loader. You may have to do it in stages.
Get the Volvo out of the way first :cool: Just be careful so that it doesn't tip over while you are jacking it up.
   / Need help! Model 91 FEL fell off prop rod. #8
OK, Hook the tractor hydraulics up. Raise the front brace bar as High as you can. Load weight into your bucket, the heavier the better. place something like a big round under the raised front brace. Roll your bucket all the way back. SLOWLY lower the front brace (raise the boom control position). The rear of your FEL should come off the ground and then you MAY be able to drive your tractor into the FEL to the rear brace stops. If not, you may be able to get the stand up pole back in place.
Once you have it on the brace stops you can raise the front brace and roll your bucket enough to finish attaching it to the tractor......
Or maybe not.......
Option 2 is a case of beer and several large friends!
   / Need help! Model 91 FEL fell off prop rod. #9
Judging from your pictures I would use a engine hoist. Check with your friends, neighbors or rental yards for one.
E/S
   / Need help! Model 91 FEL fell off prop rod. #10
I'm with Dead Horse on this one. Hook up you hoses, curl your bucket, then fill it with the heaviest thing that will fit in it. If you can get enough weight into it, you'll be able to manipulate the arms with the bucket sitting flat on the ground. One thing though, You're gonna have to move the Volvo.:D:D
Year: 2002 Make: Western Star Trucks Model: 4900 SA Vehicle Type: Truck Mileage: Plate: Body Type: (A51692)
Year: 2002 Make...
2012 Infiniti G25 Sedan (A50324)
2012 Infiniti G25...
2002 Trotwood Trailer (A50515)
2002 Trotwood...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A52748)
2023 New Holland...
2002 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2002 Ford F-150...
Unused Delta Crash...
