Need help location ring and pinion for a NAA
   / Need help location ring and pinion for a NAA #1
Daveboys
Mode, IL
Ford Jubilee
I'm looking for a ring, pinion and carrier for an NAA. If you have something or know where I can find something please let me know.
   / Need help location ring and pinion for a NAA #2
Try farmland, tangent Oregon. Hit or miss.
   / Need help location ring and pinion for a NAA #3
   / Need help location ring and pinion for a NAA #4
i checked wengers. has pinion.. rg shows as out of stock.
did an ebay search saw this. I'd check before I bought. not all them are interchangeable.. see what it really is
NAA Jubilee 600 601 2000 Ford Tractor Ring Gear and Pinion | eBay
there were other listings as well too.
might call alexanders too.
I looked at his ebay set in person and IMO they are in relatively poor condition for the price. Sometimes desperate times call for desperate measures.
What kind of damage were you seeing on the gears?
   / Need help location ring and pinion for a NAA #6
Had two sets-one actually was naa ring and pinion-appeared to have substantial gear wear-pitted bearings and the center chunk was gouged from a presumed earlier failure. Ring gear rivets had been replaced with bolts. The other was a later model set that my sources say would not work in naa. Again this is personal opinion and you should always make your own judgement on these types of things. Not knocking these guys since they are generally a good source. The parts may very well be satisfactory for you but they definitely were not for me.
   / Need help location ring and pinion for a NAA #7
withthat much damage.. i'd keep looking.
   / Need help location ring and pinion for a NAA #8
Try Skillings Tractor Parts in North Hampton ,Ohio. 937 964 1486. Second generation, knows his stuff.
   / Need help location ring and pinion for a NAA #10
they show a pinion and no ring gear.. i checked them earlier in the thread..
Year: 2002 Make: Ford Model: Econoline Vehicle Type: Van Mileage: 156,145 Plate: Body Type: 3 Door (A51694)
Year: 2002 Make...
Valvoline 80/90 Gear Oil (A53117)
Valvoline 80/90...
2010 Chevrolet HHR SUV (A51694)
2010 Chevrolet HHR...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
