Ballast NEED HELP LOCATING M7040 REAR WHEEL WEIGHTS
/ NEED HELP LOCATING M7040 REAR WHEEL WEIGHTS #1
Muleskinner
Pioneertown, So CA
2015 KUBOTA B2650ROPS
I have searched this forum with no results. Can anyone tell me where I can purchase cast iron rear wheel weights for my M7040? I need around 500 pounds per side. The rims are 24".
/ NEED HELP LOCATING M7040 REAR WHEEL WEIGHTS #2
We get wheel and bumper weights from Taylor Foundries, Wichita Falls tx.
Check with them 1-800-272-3456.
So far I've only been able to find stackable weights to around 400 pounds total. I want a one piece weight that will add about 500 pounds per side total. Like the ones you see on construction tractors like the JD 210 LE.
/ NEED HELP LOCATING M7040 REAR WHEEL WEIGHTS #5
I had the dealer fill the rear tires on my m7040 with calcium chloride which added 6 to 700 lbs per wheel. That is the best way and most economical way to go
I filled my rear tires the day I got it. I added one gallon of anti freeze to each tire for corrosion. I added 32 OZ of Slime in each front tire. I run my rears at 20 PSI and the fronts at 40 PSI. Works great in all terrain including soft sand, which is what I work in most of the time.
/ NEED HELP LOCATING M7040 REAR WHEEL WEIGHTS #7
MU;ESKINNER: I have two TLB's; 78 Kubota L295(DT) with loader/backhoe Weigh's 5500# with R-1 tires, and a 95 Kubota L-35 TLB with loaded tires, and the R-4's, and weigh's 6500#. In a face-off in soil; the L295 will tow the
L-35 backwards! If the soil is wet, the L295 may even do it it 2wd? I haven't tried it that way yet. The other way happened, when I got the L-35 stuck in mud, an brought the L-295 for the rescue mission! This is info only, and may not be cost, or time effective to have a set of each? Maybe a set of chains on the R-4's for certain jobs would work??
/ NEED HELP LOCATING M7040 REAR WHEEL WEIGHTS #8
I had the dealer fill my 30 inch tires with calcium chloride and I lower the tire pressuer a bit to bet max traction. Works really well on my m7040 tractor
/ NEED HELP LOCATING M7040 REAR WHEEL WEIGHTS #9
I filled my 14.9X28's with water and anti-freeze. It definitely helped in loader work and ground engaging work. I also foam filled the fronts.
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
300 Gallon Portable Fuel Tank (A64127)
300 Gallon...
Landhonor Skid Steer 3Pt Hitch Adapter (A62679)
Landhonor Skid...
2016 JCB 3CX 4x4 Loader Backhoe (A64194)
2016 JCB 3CX 4x4...
2018 Bobcat MT85 (A64126)
2018 Bobcat MT85...
(2) Wheel Spacers w/Caps (A64127)
(2) Wheel Spacers...
